VSS signal wire for a 91 V6 camaro
Old May 11, 2004 | 02:10 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I tried diagrams but only found a thick red wire that says VSS power or something similar. Anyone know the exact wire for the VSS signal from the Gauge cluster?
Old May 11, 2004 | 08:36 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Pasky,
Here are the wires for the VSS for you.
pin B9 from ECM to pin B of VSS on tranny= purple (signal low)
pin B10 from ECM to pin A of VSS on tranny = yellow (signal high)
pin C1 from ECM to cruise control = red (VSS output (2000 p/mi)
pin B11 from ECM to I/P(pin 1 on connector C2) speedometer = gray (VSS output (4000 p/mi)
pin D16 from ECM to P/N switch = orange/black (p/n signal 12 volts).
Hope this is what you wanted.
Old May 12, 2004 | 12:14 AM
pasky's Avatar
Thanks trickster, but I need ones from inside the car, I don't have the ecm plugs anymore, know where I can locate it under the drivers kickpaneL? Thanks again.
Old May 13, 2004 | 12:35 PM
pasky's Avatar
Where'd ya go man .
Old May 13, 2004 | 01:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry man, the VSS buffer is located under the dash on the passenger side near the ECM if your car was a VIN "E" prior to the engine swap. It will have two connectors (C1 & C2) on it, one will have five wires and one will have two wires. C1 will have pins labeled "A" & "C", "A" is a yellow wire and "C" is a purple wire, both go to the VSS. C2 will have pins labeled "A", "C", "E", "F", & "H". "A" is ground (black/white), "C" is instrument panel (brown), "E" is cruise control (red), "F" is ECM (brown), & "H" is gauge fuse on fuse block (pink/black).
If your car was a VIN "T", "F", or "8" prior to the swap, it is as I described in my first post. On these models there is no VSS buffer module. Hope this helps you.
__________________
Old May 13, 2004 | 03:41 PM
pasky's Avatar
So C (brown) would be the wire I need to splice the VSS signal from the LT1 PCM into the "Gauge cluster"? Thanks.
Old May 13, 2004 | 04:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you have not removed the VSS buffer from your car, pin "C" (brown) goes from the VSS Buffer to pin #1 on connector C2 of the instrument cluster. Pin "F" (also brown) goes from the VSS buffer to the ECM (PCM). Here are the diagrams.
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old May 13, 2004 | 04:57 PM
pasky's Avatar
Thanks again man, damn you change sigs like underwear .
Old May 13, 2004 | 05:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
How do you like it?
Old May 13, 2004 | 07:27 PM
pasky's Avatar
This and the last one were pretty good. I like this one more of the two.
Falcon50
Aug 22, 2020 03:26 PM
Elephantismo
Feb 13, 2019 12:51 AM
meeklay812
Oct 1, 2015 03:46 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
Tweeks25
Sep 17, 2015 08:04 AM
