Altenator problem!!!!!
Old May 19, 2004 | 08:11 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Ok, so the new motor is in, it runs, my alt is new, i have only one wire to it from the batery to the small screw on teh back of the alt, the plug on the alt is bare, i have no wires runnin to it, is this the reason its not chargin my batery or what, any ideas...
Old May 19, 2004 | 08:50 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, the connector on the back of the alternator should be a two pin connector and have a red wire and a tan/white wire going to it. The red wire is a fusible link going to the starter solenoid. The tan/white wire goes to the FP-FAN fuse on the fuse panel, it also splits off and goes to the coolant fan relays
Old May 20, 2004 | 08:26 PM
Charged350's Avatar
Car: 87 IROC Z28
i dont have that wiring going to it, all i have is that red wire from teh battery to the small nut on the back of the alt
the two pin connector is nowhere to be found, so where do i need to hook up the wires from where the pin connector used to go, i thik one goes right to the small nut on the back of the alt, and another one is for the gauge...please help me out, im eating batteries left and right....
Old May 20, 2004 | 08:57 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Charged350,
Those two wires should be in the same wire loom on the driver side as the wires for the fuel injectors and the MAF sensor. Check that loom and see if the wires and connector are possibly tucked up inside out of view. The connector will plug into the bottom of the alternator, at least it does on my car. Let me know what you find!
Old May 28, 2004 | 11:43 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I think hes talking about the single wire that goes from the back of the wire to the distribution block. The stock one is in that hard black shell.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
