? Re Rear View Mirror Wire??
Old May 22, 2004 | 12:21 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I have installed a Auto Dimming Rear View Mirror as well as the proper connection.
The only wire that is NOT hooked up yet is the Green Back up light wire. I am having a hard time finding it.
1. Does anyone know where exactly it is located on a 89 camaro or how to test to see if it is backup wire?
2. The mirror's power light does not light up. Do the all 3 wires have to be connected for the green light to come on or as long as power and ground are working the mirror should work regardless of the backup wire?
I would appreciated any suggestions.
Thanks.
Old May 22, 2004 | 02:14 AM
Morley's Avatar
Power and ground are all you need to make the mirror work, I just installed one of them in my 85. BTW I didn't hook up the reverse light wire to the mirror either.
Old May 22, 2004 | 11:53 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Well, i guess the mirror is toast then. The light does not come on.
What in the mirror fails the most?
Thanks..
Old May 22, 2004 | 02:31 PM
Morley's Avatar
Thanks..
Play with the on off switch a bit, it may just have corroded contacts.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
stalkier
Aug 13, 2015 12:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
