Left turn signal stays lit
Old May 25, 2004 | 11:04 PM
86transamws6's Avatar
Car: 88 IROC - 86 Trans Am
Engine: L98 Carbed - 350 Carbed and boosted
Transmission: auto - T5
I tried taking out the left side turn signal bulbs one by one. And the blinker would just stay on. So it can't be a bad bulb. I also replaced the flasher and still no luck. any ideas?
Old May 26, 2004 | 12:41 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
What vehicle is it on?
Were the outside bulbs staying lit as well?
Old May 26, 2004 | 12:52 AM
Wezzeles's Avatar
Car: Camaro
my car has done thesame exact thing for a year. all the lights work
but still no left turn blinking.
all the lights stay lit
mines a 92 rs
still havent figured it out
Old May 26, 2004 | 03:56 PM
oh sorry, the 88 IROC, and ya the indicator light and all 3 left turn bulbs outside
Old May 26, 2004 | 09:28 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Mine is doing this too, any help guys?!? PLEASE!!
I am guessing bad flasher or fuses? Do the turn signals use a different flasher than the hazards? Because my hazards work fine. My left turn signal stays lit all the time, doesnt blink at all.
Old May 26, 2004 | 10:12 PM
AM Racer's Avatar
Usually when the dash turn indicator stays lit, there's a bad or missing ground wire.
Old May 26, 2004 | 10:33 PM
missing?
Old May 26, 2004 | 10:51 PM
AM Racer's Avatar
Missing as in broken or ripped off from something snagging it.
Old May 26, 2004 | 10:55 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The hazzards do use a different circuit/relay for operation.
If the signal outside is staying lit, it would seem your getting power leaking in from anoother source. If the flasher relay is bad, neither side will work because both indicator sides are powered from the same, single relay.
The inside indicator is tied directly to the wiring that leads to the outside lamps. Not certain about all, but, the few I've dug through the wiring, the inside indicator was tied at the bulkhead on the inside.
Assuming the indicators are only lit with the car on, I'd start by pulling the turn b/u fuse and see what happens. Guessing, the problem will still be present. Next would be to pull fuses from circuits that are only on with the ignition and note what happens.
Old May 26, 2004 | 11:25 PM
well ya, I just dont know how it wouldve become missing
Old May 27, 2004 | 05:22 AM
Hmm thanks man, I will look into that.
Old May 27, 2004 | 08:39 AM
You're from Auburn eh? You ever cruise downtown Worcester or go to the summer nationals?
Old May 27, 2004 | 01:55 PM
All the time, this will be my 7th year going. You prob saw my car last year, except it looked stock... red with silver GFX. You'll see me there this year too
Anyways, I'm gonna check out my relay and flasher tomorrow...probably replace them and see if it fixes the problem.
Old May 27, 2004 | 02:29 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
Probably not going to help but when I took apart my steering column the FIRST time to tighten it the left turn signals stayed solid and my lock cylinder wouldn't move. So I had to pull it again and line my lock cylinder up correctly and when everything was back together my turn signals worked fine.
later
Old May 28, 2004 | 01:35 PM
Well I beleive I fixed it. I had alot of dirty/bad grounds and connections. I also bought a new high beam headlight because the old one had a broken ground tab on it. All seems to be better now
Old May 28, 2004 | 02:38 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I had the same problem and it was caused by the connection in the pass side front turn signal, it's the top wire in the pic,
Old Jun 2, 2004 | 11:40 AM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
im having a similar problem. the other day i was stopped at a stop light waiting to turn and all of a sudden my blinker stops blinking. so i tried the other side and nothing. both sides stay lit and wont blink. i checked fuses and bulbs but nothing. my hazards work tho so i know its not my bulbs. where is the relay located? i think that might be it.
Fronzizzle
Mar 18, 2019 08:29 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
