Green wire from dimmer switch?
Old Jun 2, 2004 | 11:24 PM
padmos's Avatar
Car: 89 Camaro
Transmission: 5 spd
I am in the process of redoing my entire interior, I was hoping to have a site with pictures before I made my first post but I’ve run into a problem that I can’t figure out and I’ve been searching the boards for hours.
I had to replace the **** that controls the interior and headlights with a couple of switches. Everything is working fine except I don’t think I am providing power to the right wire to light up the gauge cluster, when I hooked up the small green wire that comes out of the dimmer switch to a live wire the gauge cluster lit up just like I wanted it to. However this wire is a very thin gauge compared to some of the others being used and I feel like it would burn out if I left it on too long. Is this the only wire that brings power to the backlighting of the gauge cluster or am I missing one? I feel like it has something to do with the old dimmer and a larger wire is supposed to carry more of the load, I don’t care about dimming the lights I just want on and off but I also don’t want the wire to catch fire once I start driving. I know what all the wires coming out of the dimmer switch do accept for this green one, and a large purple wire. I saw some diagrams but vital parts are too blurry for me to make out.
1) is the green wire all I need to hook up to illuminate the gauges?
2) if anyone has a simple list of the color of the wire and the destination that would be even better. Example:
brown – tail lights
yellow – head lights
white – ground for dome light
(im just making this up I can’t remember off the top of my head but you get the idea)
Any help would be immensely appreciated. Thanks
Old Jun 2, 2004 | 11:36 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
you need to look up trickster and see if he has a diagram for this he has one for everything ive seen on here im sure he does and hes very helpful to everyone
Old Jun 3, 2004 | 12:12 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello padmos,
Welcome to the board and thank you thegeneral. Here is a schematic of the interior dimming which shows the wires for the gauge lights from the light switch. As you can see from the schematic, there is a dark green wire that goes from the light switch to the "INST LPS" fuse on the fuse panel and from there it is a gray wire to all the gauge lights with a black wire for ground.
Old Jun 3, 2004 | 12:19 AM
THEGENERAL's Avatar
i knew you could come thru for him .......
Old Jun 3, 2004 | 09:04 AM
padmos's Avatar
Car: 89 Camaro
Transmission: 5 spd
thanks guys
Thanks trickster. That was exactly what I needed and so fast too, now I won’t have to worry any more than usual when I’m driving at night.
Old Jun 4, 2004 | 09:23 AM
IroczInOz's Avatar
Trickster what book do you get all those diagrams from??
GM service manual??
Old Jun 4, 2004 | 09:26 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yep!!!!!!!!!!
Old Jun 4, 2004 | 09:35 AM
IroczInOz's Avatar
Sweet I need to find one of those!
The haynes manual is pretty useless.
Ghettobird52
Jul 5, 2024 11:18 PM
Dkelz313
Apr 7, 2016 10:38 PM
The_Phoenix
Feb 4, 2016 07:10 AM
overdriv
Aug 20, 2015 03:52 PM
355sbcTPI
Aug 19, 2015 04:38 PM
