Low Voltage
Old Jun 12, 2004 | 01:45 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Low Voltage
I jsut put a new 160 AMP alternator because my volt guage keeps saying it is at 12 volts or below. I have a new battary as well. I was thinking that maybe the wire to the distribution block may be going bad. I woudl like to use 4 guage wire but it wont fit in the distribution block so i was thinking of leaving the wire that goes from the alternator to the distribution block intact and not replace it and run a wire from my alternator to my battary directly. So i wuld have the power from my alternator going to the distribution block to power what ever needs powering. And have a thicker guage wire from the same spot on the alternator go directly to the battary. Would That cause any problems since the battary would then be charged from 2 spots insted of 1?
Old Jun 14, 2004 | 03:42 PM
Tyler-88's Avatar
check the voltage between...
battery+ to battery ground
battery+ to chassis ground
back of alt+ to bat ground
back of alt+ to chassis ground
that should help you out alot more to see what is wrong
327IROC85
Sep 23, 2015 12:11 AM
gta_knight
Sep 17, 2015 03:48 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
