Turn Signals Dont Work?
Old Jun 24, 2004 | 10:56 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
my turn signals dont work the hazards do tho,everytime i put in a new fuse it pops it right after,whats goin on
Old Jun 24, 2004 | 11:09 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Turn Signals Dont Work?
Hazzards use a different power circuit.
If either direction doesn't work and blows the fuse, I'd start at replacing the turn signal relay. Sounds as though it may be cooked and grounding itself out.
Old Jun 24, 2004 | 11:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Do your back-up lights work?
Old Jun 24, 2004 | 11:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What deadbird refers to as a turn signal relay is actually a turn signal flasher and it is located clipped to the fuse block bracket.
Old Jun 24, 2004 | 11:44 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
no as a matter as fact the back up lights dont work
Old Jun 24, 2004 | 11:49 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the turn-b/u fuse.
Old Jun 24, 2004 | 11:50 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
thats the one that keeps blowing,20 amp right?
Old Jun 25, 2004 | 12:00 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Nope, it's a 10 AMP. Start checking the wiring for the turn signals and the back-up lights. you might also check the wiring to the back-up switch.
Old Jun 25, 2004 | 12:06 AM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
do i start following the wires from the steering column
Old Jun 25, 2004 | 12:14 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I would first start checking all the light sockets for corrosion or a broken bulb that is shorting out.
Old Jun 25, 2004 | 12:22 AM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
good thinking
Old Jun 26, 2004 | 10:42 PM
408maro's Avatar
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
i checked the bulbs they look good all of them,im thinking of just getting another steering column
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
