Alternator/ Battery Issues ?
Old Jul 1, 2004 | 06:04 AM
shatteredgently's Avatar
Car: 1992 Firebird
I am having a weird issue on my '92 Firebird. When I was driving down the road, it just completely died. It appeared to be a bad battery so I replaced it and it worked fine. However, my car had been keeping around 13-13.5 volts on the old battery and as soon as I installed the new one I noticed that it stayed barely above 8. I thought maybe the alternator is not working correctly, so I replaced it with a new one. Fired it up and it went to about 9 volts, then I turned on my cd player to see if that would drain it and it sure did. The voltage went down and I turned the bird off. I decided to see if maybe jumping the car would help, so I did and it went up to about 11-11.5 volts. I let it run for awhile and it held pretty much in that area so I shut it off and went inside because it started raining. I came back outside about an hour later and fired it up and it barely got above 8 volts. I have no idea what is going on and am hoping since I am a newbie at these cars that it is something simple that I am not thinking of. I thought maybe it could be the voltage regulator? Maybe a wire shorted somewhere or is touched something metal and losing power? I appreciate any help on this.
Old Jul 1, 2004 | 07:12 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check the fusible link that goes from the starter solenoid to the wire harness on the alternator. (red wire). Also check all your battery connections.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
WIzmo
Aug 30, 2015 02:30 PM
djmarch
Aug 9, 2015 05:27 PM
