Fan Blower Motor Issues
Old Jul 4, 2004 | 05:53 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Ok, I am having this very strange issue with the fan controller for the blower motor.
I can get the first three settings fine, but once I get to the 4th, (High) setting, the blower motor just turns off.
I know the blower motor gets a 12v feed, but I am not sure how it changes speed. There is a little coil resistor pack right near the Evaporator Coil, and I checked it. It physically looked fine, I pulled one out of my Camaro and it worked good too. So that isn't a problem.
I Changed the relay with one that I know is working and it didn't change anything either. On top of that, even with the relay unplugged, the fan motor still works and I can still change the fan speed. I am not even sure what that relay does.
Ok, last, I switched the fan selector switch on the HVAC controls, thinking that could be the problem. Alas, it was not the problem and I still can't get the high speed.
How would I go about trying to find out what was wrong? It hasn't been working for a few days now and I decided to try it again while I was burning up in my car. It worked for about a minute, until I hit a bump and the high speed went out again. I checked all the wires and they look fine.
Also, I just changed the blower motor a few months ago, so I doubt that could be bad.
AHH!!!
Help me please
Old Jul 5, 2004 | 01:34 AM
MdFormula350's Avatar
this diagram might help.
the relay works with the high speed like u said.
Old Jul 5, 2004 | 12:21 PM
Sonar_un's Avatar
Car: '86 T/A
Thanks, I hope it helps..
I will check that relay again, but it would be wierd if two relays were bad. However, it would explain how the fan turned off when I hit a bump.
Old Jul 6, 2004 | 01:12 PM
Sonar_un's Avatar
Car: '86 T/A
Well.. I did a little more investigating into what was going on with my motor, and I still can't figure it out.
I have 12v from Red to ground, 12v, from orange to ground, 12v to the blower motor when the switch is on high from purple to ground, yet, the motor isn't turning on?
Now, I really don't understand why the motor would work on the lower settings but not on high, its too simple to have any sort of resistors in the motor itself to limit the actual speed, thats all done externally, as long as the motor is getting 12v, it <i>should</i> work? Or am I wrong?
I've haphazardly replaced everything associated with it, and I am getting good voltages throughout, so I doubt its a connection issue.
The only thing left is the blower motor itself, but I just don't see how.
Old Jul 6, 2004 | 02:00 PM
Sonar_un's Avatar
Car: '86 T/A
I figured it out.. the infamous red-wire of death syndrome that plagues these cars.
Here's a pic
Old Dec 4, 2005 | 12:46 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
where is that located at?
Old Dec 4, 2005 | 04:45 PM
Vader's Avatar
On his car, silly.
Old Jan 7, 2006 | 11:46 AM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
sorry to resurrect this one from the dead, but I remember having this problem myself. is there any problem with simply cutting both ends on that fusible link power connector and simply crimping them into one of those round crimp connectors? Because that's what I did... wanna make sure that won't blow anything up and will work fine.
Also, my blower motor doesn't work in High speed. Other 3 settings are fine. Should this be the relay? Thanks for the help
Old Jan 7, 2006 | 08:33 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Just get a whole new assembly. Air Control Assembly. the switch might of been toast.
Old Jan 7, 2006 | 09:52 PM
luke4907's Avatar
Engine: TPI350
it was the blower motor relay.
Old Jan 9, 2006 | 12:24 AM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Originally posted by Vader[/B]
Lmao, Extremely Stupid Connector.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
Leggman1
Aug 6, 2015 04:15 AM
