No power going to light motor, ur thoughts?
Car: 1994 Firebird
Engine: V6 3.4L
My flip lights use to work great, then worked when they wanted, now don't work at all. During my lunch break at work, i went to test the wireing going to the flip lights, and apperently there is no voltage going to the flip light motors. my switch is new (parking lights go on and the head lights go on, so i guess the switch provides enought voltage when i turn it on)
What could be the cause of this?
-burnt/damage wire somewhere?
- Relay? (is it 1 for each or, 1 for both?-where is it located?)
that's all i can think of.
Car: 1994 Firebird
Engine: V6 3.4L
oh yeah, i venchange all the fuses in my fuse box,
the flip light motors are fine ( i changes them before)
there is no power going before the flip light motors, so, wouldn't be that....
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I'm not talking about fuses in the fuse block. I'm talking about fusible links, see attached picture. You will find them in the front lights wire harness near the left hand radiator shroud.
CarGuyDennis
137
12-06-2016 11:02 PM
