Tach acting up
Car: 89 firebird
Engine: 2.8
Transmission: auto
Tach acting up
Just recently my tach has been acting up. It works fine most of the time but when I floor it the tach needle bounces back and forth along the entire range and then goes down to 1000 rpms or less. I can hear the engine accelerating so I know something is wrong with the tach. What does the tach get it signal from? Altinator, distributor, something else? I have recently installed a new accel coil, accel ignition module (same thing happened before and after the ignition module) an MSD 6A and new plug wires, although I dont think the tach has much if anything to do with these things. Maybe the MSD if the signal goes through that somehow? Thanks for the help!
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep, chances are the MSD box is the culprit. I've got a Digital 6+ and had to drive my in-dash tach from the tach terminal on the MSD box. I don't know if the 6A box has that or not. Check if you have a tach filter on the firewall, if so supposedly you can splice the tach wire around that and work fine as well.
Hope this helps you out. You can call MSD about this as well, but chances are they're gonna sell you a "tach adapter" that would probably work fine but may not be required for you.
Possibly, Trickster, but chances are the multi-strike signal is what's causing the tach to get all confused.....
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As it says in the MSD instructions, you have to use the tach terminal on the box to drive the tach.
Car: 89 firebird
Engine: 2.8
Transmission: auto
Ok I dont have the MSD 6A instuctions. I bought it used. Which is the tach termainal? I have added an MSD box without using a tach terminal but it was a MSD 5 and one time with an MSD 6A but that was on a 327 mtor in the 85 firebird.... no comuter and a basic chevy coil set up... on 2 wires instead of 4. Also in the set up I used the MSD connecting harness to keep from splicing wires and no only 1 of the 2 connectors attach directly to the coil.
Engine: 383 Carb
Transmission: 4L60
http://www.msdignition.com/pdf/6series.pdf
The tach terminal is a male quick disconnect terminal on one end of the box, if i recall correctly.
Car: 89 firebird
Engine: 2.8
Transmission: auto
Thanks for the information. According to the MSD instuctions you sent it says to bypass the tach filter. Where is that and how do I do it? According tho them they decribed the same problem I have and say that how to solve it.
Car: 89 firebird
Engine: 2.8
Transmission: auto
No I am not using the tach termanial on the box. The MSD directions say not to use it. It says to just bypass the tach filter. If I decide to use the tach termanial on the box the stock filter would still be inline and causing the problem. So where is this tach filter? What does it look like? Please help!! I followed the white wire on the grey connector from the coil and along it was a grey 1 wire connector in the middle of this wire for no appartent reason .... unless the connector is the tach filter itself? I have no clue? to bypass it would I just cut it out and connect the wires with a butt splice connector? If this is not the filter ... does anyone know where it is and what it looks like! Thanks!!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On my 89 camaro, that gray connector you are talking about is a tach diagnostic connector for checking the RPM's as they come off the ignition coil.
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
The tach filter is located in the loom(harness), hidden a short distance from the coil connector on a 5.0 E Vin 92RS. Hope this helps. Good Luck
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
I think that grey piece is the filter. I just got a MSD 6A and had the same problem. I disconnected the filter and connected the tach terminal on MSD to the white wire that goes to the tach not the coil. Leave filter disconnected. Everything works great. No codes, tach reads over 3000rpm.
RedLeader289
May 28, 2019 01:47 PM
