Getting a key made??
Car: 1989 IROC-Z
Engine: TPI 350
Where in the world can get a key made for my 89 IROC?? Its got that annoying VATS crap. The dealer told me they dont have the info on anything older than 90. So they cant just tell me what i need.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Re: Getting a key made??
Car: 1991 Trans Am
as far as i know a dealership is the only place you can get a key with the resistor made it runs a little of thirty dollars just try calling around to different dealerships other wise get an ohm meter and check the resistor in the key. here is a helpful artical on the system in general, it also includes a table for the ohms and key number so you can just tell the dealer ship what you need if they dont have the equipment to check. http://home.t-online.de/home/O_Scholz/vats.html
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you lose the key? If you pull the lock cylinder out you will see a code etched on it. If the original cylinder has not been changed, the dealership can cut you another key. They will also need to know what the resistance code was. I have heard from others on the board that Ace hardware carries the coded keys as well as some locksmiths. Check around.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
any good locksmith can make one.
or for a emergency backup, do what i did.
measure the resistance of your key with a ohm meter.
buy a resistor with the correct resistance (20 cents for a pack of 10)
goto walmart/ace hardware/ect and get a regular key copy for about one to three dollars....
keep the copy and resistor with the car. even if someone tries to use the key, it will never start.
when you goto use it, reach under the dash and unplug the tiny vats wires connection.... shove the resistor in there, then turn the key.......
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Nothing to add, except to say that I'm sympathic: I had a key made for a 99 Chrysler at a cost of $104 with key fob.
JamesC
JamesC
Car: 91 Camaro Vert
JamesC
JamesC
when i asked about the keys to my old VW (laser cut, switchblade keys with remote built in), they said they cost a little over $200.
Car: 1989 IROC-Z
Engine: TPI 350
I dont have the original key anymore. Thats why I need a new one. I know the cylinder has been changed more than once. One owner took out the VATS somehow and the guy I bought it from had it put back in. I lost the key just after I got the car and havent been able to do anything with the car...And now it looks like Im goin to have to sell it.
morrow
Jan 13, 2024 12:29 PM
