fuel pump cut off switch
Old Sep 1, 2004 | 05:55 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
has anyone ever wired up a switch(toogle) that i can mount in the ashtray. so that i can shut of my fuel pump and turn it on whenever i want. kind of for a safty purposes and theft. I was thinking something like the fan switch but maybe using the fuel pump relay but i dont want to mess it up so if you guys could come up with something or if you already have the anwser that would be awesome.
Old Sep 2, 2004 | 07:38 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
For safety you already have the oil pressure switch. For theft i would go with a starter disable instead of a fuel or ignition disable with ignition disable being second.
Old Sep 2, 2004 | 01:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The oil pressure switch doesn't shut off the pump if pressure drops below the 4 psi set point. It is merely a backup to the fuel pump relay. If the relay fails, the oil switch powers the pump, assuming 4 psi pressure.
i would disable the starter.
Old Sep 2, 2004 | 03:46 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
how do you disable the starter?? Details if possible. Also, why wouldnt a fuel pump switch work?? There are too many people saying that it should work, but I want to know?
Also, how many amp switch will it be enough to dissable the starter and run it as well. And the fuel pump, how much amps for that too.??
I know I am asking a lot of questions, but I need to protect my 1 out of 500 pro/am. Thanks.
Old Sep 2, 2004 | 06:48 PM
dankhound's Avatar
Car: 91 RS
You dont need a really high amp relay to disable the starter. Just wire a relay into the ciruit coming from the ignition switch. Its not that the fuel relay disable wont work. Its just that theres easier ways to do it.
Old Sep 2, 2004 | 08:48 PM
Do you need a relay or can you use a toggle switch. I have a 20amp switch with an inline fuseable link thing. Can I just splice the switch into one of the wires??
Also, there is a purple wire in the center console that can be spliced into to disable the car to start thinking that its in gear. Is this a better way to go??
If you guys have any schemattics on how to do thid I will appreciate it.
Old Sep 3, 2004 | 04:34 AM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
my 86 trans am had a fuel pump shut off switch, two of them actualy one under the dash and one hiden under the rear seats, they worked. The person that installed them was the previous owner he was an electircal enginer.
Old Sep 3, 2004 | 11:02 AM
dankhound's Avatar
Car: 91 RS
Wiring the switch in the area of the park/neutral switch is a great idea. I think a 20 amp switch would be enuf for that circuit but you really should test the current draw on the circuit to be sure.
Old Sep 3, 2004 | 01:58 PM
I got it figured out, I will wire two rocker switches, one for the tranny (purple wire) and the other for the fuel pump (tan w/ white wire) I thought of perfect place where to hide them both. The thief will never find it, even if he had hours to look for it. Heheheheh.
If I were to get a 30amp switches with a 20amp fuse would that hold up most of the car stuff. Cuz we are talking about 200wats of power for the 20amp fuse (roughly). Or do I need a bigger fuse. Whats your recomendation???
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
