Pop-Up Light Question - Wiring?
Old Sep 5, 2004 | 03:25 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I was just wondering exactly how to the headlights know to pop up? From the switch I would assume it goes to a relay that runs the actual bulbs... but I wonder if there are two relays, one for the bulbs, and one for the motor...
either way, the reason I ask is because about 1/4 times I turn on my head lights, they won't pop up, but the lights are actually on.. they kinda make a weird line of light shine on the ground throught my gfx...
when this happens I can go out and turn them by hand no problem, or I can just sit and wait, and usually they just randomly pop up... most of the time I just drive with my fog lights on because they are... well.. they are...
I'm wondering if it could be a wiring problem, because if only one headlight was not working properly, I would assume the motor was not working correctly.
The wiring probably goes like this picture I attached
the reason I think this, is because the motors obviously still have power when you turn off the headlights because they are still going down as the bulbs are off... but then I get confused because when the headlights are coming down you can flip the parking lights on and they will stop right where they are... I think that the relay that runs the motors is like 2-stage or something... or maybe its a transitor and not a relay...
Thanks for any help, I've been trying to fix this problem for a while
Attached Thumbnails Pop-Up Light Question - Wiring?-firebird-headlight-wiring.gif
Old Sep 5, 2004 | 04:03 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
You probably have a loose wire somehwere and it probably engergizes the motor when bumped during driving. I would go ahead and check the wires to see if they are loose, or chiped.
It could be the motor itself, but unless it makes noise I would not worry about it.
Check the wires, it is an old vehicle.
Good luck
Old Sep 5, 2004 | 05:59 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are three relays to be exact, the isolation relay (Main one), left actuator relay, and right actuator relay. If you will do a you will find the wiring schematics that I have posted several times on the board.
Old Sep 5, 2004 | 10:54 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It is a simple fix. The solid gel inserts inside the large nylon gear have broken and crumbled to a spoonfull of chunks. I sell two headlight repair kits that will solve your problem. TDS 207280 and TDS 209280.
Lon Salgren
Top-Down Solutions
Old Sep 6, 2004 | 03:02 AM
ScrapMaker's Avatar
if it was a problem with the motor internals wouldn't individual motors have issues? rather than randomly popping up? this is a strange problem because I can let the car sit with the lights on and they will just pop up on their own... I don't think it has to do with bumps... very strange
also I did search but I must not have put the right wording because I couldn't find much... almost just random stuff not having to do with headlights at all... strange search engine..
Old Sep 6, 2004 | 09:56 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try this link:
https://www.thirdgen.org/techbb2/sho...headlight+door
Old Sep 7, 2004 | 12:52 PM
ScrapMaker's Avatar
yes thank you for the link, I did eventually find that post... really good information.. looks like I've got pretty much all I need to know to fix it the right way.... thank you very much...
I still kinda wonder why the headlights would pop up randomly, whether I'm driving or not. very strange problem... years ago I even took it to a shop and had them "fix" the problem, I believe all they did was change out a relay up near the drivers side MC (the group of fuses).... well it never really fixed it to say the least, although it seemed to work very well for a long time, with minimal problems... I wonder if some wiring problem can cause the relay to wear out real quick? I guess it would be that one main relay that controls both headlamp motors at the same time...
thanks
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
