Wireing a spot like to the dome light
Old Sep 6, 2004 | 03:44 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
Hey "i kno trickster will be in this thread lol" but this goes to everyone even better if yous have done it. when i ripped out my horrible head liner i took off the dome light cover as well cause it looked horrible.. its all yellowish and stuff..but since this is the electrical board i'll stay on that topic, i replace my normal white dome light buld to a red/blue one and both look cool, but i was thinking ,.. is there a way to wire up one of those little spot lights up to it.. that would be so bad ***...having a spot light as your dome light.. ha awsome.. like there would also be better uses for this... what if someone touched your car and the alarm went off.. then alls people see is spot lights.. that would so stand out. even if your cruisin down the road and turn the light selector to the left and was cruisin with your spot light on.. thatd be hot ****.. help me out on this tho!!!
Old Sep 6, 2004 | 04:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello crazy3rdgen,
Did you expect me not to read something on my board? What kind of spotlight did you have in mind to put up there. I went to the junkyard and got one of those dome lights that had the two reading lights to install in mine. I also took the whole setup when I did it and wired it into the existing wire harness
Old Sep 6, 2004 | 04:30 PM
Car: 2002 SS
Engine: Ls1
trickster your like the smartest with this electronic stuff lol i knew you had to be the first to reply lolol thanks tho but theres 2 1 at jegs and 1 at summit..
this one at jegs looks like the simplist.
http://www.jegs.com/cgi-bin/ncommerc...86&prmenbr=361
just connect the positve of the strobe light to the positive of the dome llight? then neg to neg? which is neg which is pos on the dome light?
______________________________________________
then theres this one at summit.. i do want the best one and these are alittle more expensive.. just by alittle bit. i want her as bright as possible if you have any suggestions on which on but anyways heres the one at summitracing.com
http://store.summitracing.com/defaul...t=strobe+light
thanks for your time trickster : )
Old Sep 6, 2004 | 04:36 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
IIRC, the orange wire is the positive and the white wire is the negative. At least on my 89 Iroc it is.
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
