wire problem?
Old Sep 9, 2004 | 07:28 PM
popeyealica's Avatar
Car: 1991 chevy camaro
wire problem?
two things. first i just gave my camaro a tune up. now the temp gauge doesnt work what could be unplugged? second i just replaced the alt. and batt. now when the car hits a bump or i slow down all the power shuts off then in a plit second comes back on. i hear alot of enine noise through my speakers. and when the power dims anytime i roll down the window, put my foot on the brake, or even hit my blinker the battery needle moves. what could be wrong?
Old Sep 9, 2004 | 07:53 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
1. The temperature sending unit mounts in the driver's side head, between the #1 and #3 cylinders. There's a single green wire that goes to it. That's what's unplugged.
2. Check your battery cables, one of them could be loose. Also check the wiring going to the alternator. It could also be loose. Either of these would cause the voltage drops you're describing.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bert87
Aug 23, 2015 03:50 PM
Fronzizzle
Aug 17, 2015 02:52 PM
