Painless H4 headlight harness with stock bulbs?
Old Sep 14, 2004 | 06:29 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I bought this:
http://store.summitracing.com/defaul...artSearchFlag=
and had those cheap H4 adaptors from ebay... you know, the ones with the blue bulbs that are really dim? lol
Anyway, I bought Sylvania Cool Blue lights. They are great! A little brighter than stock, and not yellow-ey.
Problem is, they used to work fine both high and low beam, but now high beam just is the two middle lights. On low, the outer work fine. I think a solenoid blew on the harness... but I'm no good at this stuff.
Anyway, my question is, does this harness change the wiring? I have read that it is for the H4 style bulbs, which I thought were a different pinout! So, can the Sylvania's be brighter if I rewired it? Is that why the solenoid blew?
Old Sep 16, 2004 | 06:54 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Anyone?
Old Sep 24, 2004 | 04:34 PM
1quikformula's Avatar
Car: 1991 Pontiac Formula
Engine: 350 C.I
Transmission: 700R-4
This link explains the different pinouts between the H4 and the sealed beams. Hope this helps you
https://www.thirdgen.org/newdesign/t...es/connect.gif
Old Sep 24, 2004 | 06:17 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Weird! So the lights shouldn't even work! I wonder why they do...
Old Sep 24, 2004 | 06:23 PM
Engine: 350 C.I
I was having the same problem with my car, but i had converted my headlights to the H4 style and both the high and the low lights would be very dim.
Old Sep 25, 2004 | 12:33 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yah, same here, that's why I went back to sealed beam. Unless you get the actual blue headlights, everything else is going to be dim.
Old Sep 25, 2004 | 11:41 AM
Engine: 350 C.I
what you can do to make that kit work is to change the pin location aroun, so that it can match with the sealed beam patern. That's what i had to do get my H4 to shine like they should.
Old Sep 25, 2004 | 11:52 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
That's the harness I use on my TA and everything works as it should.
Did you make any modifications for it to work on the Camaro setup? AFAIK there is one or two to be made, I don't know offhand what they are.
Old Sep 25, 2004 | 03:00 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
So the harness works fine with your stock bulbs? Now I'm lost!
Old Sep 26, 2004 | 02:10 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
I have a TA, two bulb setup. When I said that I was referring to 1quik who said his were dim. Even with the stock bulbs they were at least as bright as the stock harness, if not brighter.
Old Sep 26, 2004 | 04:09 PM
Engine: 350 C.I
That is true but I'm not using the Harness my was stock, and when i changed over to the H4 setup my ligths got dim because the ground the the power were not where the're suppose to be. All I did was change the wires around to fit my needs, and yes, right now they're brigther than stock.
Old Sep 26, 2004 | 08:18 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Nevermind. Reread and got it.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Fox118
Sep 1, 2015 04:07 PM
stalkier
Aug 21, 2015 01:54 AM
