To Glow or not to Glow...
Old Sep 17, 2004 | 05:02 AM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
I am in the process of installing 145mph glow gauges faces on my 92Z but I have run into a couple of problems. When I was disconnecting my fog lamp switch I accidentally made a bad contact with the end of a flathead screwdriver. I replaced the blown fuse but have now noticed that the dimmer lights for my speedo cluster don't come on. Would these lights have been affected by this, or did I do something else wrong? Have I killed a relay, and if so where is it located? Also, exactly which wire do I use to power the gauge faces and what color would it be? Any help will be much apprecaited- Thanks
Old Sep 17, 2004 | 01:37 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
could have affected the switch itself possibly have you tried to bypass it?
gta892000
Aug 11, 2019 11:16 AM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
andy74
Sep 3, 2015 08:41 AM
Brendankup
Aug 30, 2015 01:46 PM
TPIJeep
Sep 12, 2001 09:44 PM
