bypassed VATS, now a yr. later i think its messing up
i bypassed my vats on my 91 firebird over a yr ago, and have had no problems till now. heres my problem, my car will start for about 2 seconds then die. i had it in the shop and they can find nothing wrong with any thing. colud this be a long time result of the bypass ? please help me if you can
i was thinking that to trickster, but i pulled the resistor i had used out and tried to start it and it wouldnt even fire for the 2 seconds then i put the resistor back and it will run for about 2-3 secs and die
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If that's the case then I think that your problem might be elsewhere. You don't have the engine size listed so I don't know if you have a TPI or TBI set-up. What kind of fuel pressure do you have and have you checked the injector fuses? When was the last time that you changed your fuel filter and PCV valve?
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you need to see what you loose once it dies.
#1 hook up a fuel pressure guage. start the car let it run till it dies see what your fuel pressure does while it runs for a few seconds and what it reads once it dies.
#2 If the first step checked out ok then get a noid light and hook it up to an injector harness. start the car and see if it keeps flashing or if it stops and as a result the eng. stops. (this may be a little harder due to the lack of one cyl.
#3 get a spark tester!!! hook it up to one of your wires and run the car see if it stops while the eng. is still turning
#4 let us know what you are loosing and causing the eng. to die
Originally posted by grn420
i have a v6 with a tbi setup ive checked every thing i can think of. i have fule pressure, fire, the injectors have power im at a loss here
But, in any case, check the fuel pressure for sure.
you were right
its a MPFI system and once again you guys helped me out. It turned out to be one bad fule injector, it was getting power but the injector itself was grounding out causeing the rest not to work. thanks alot guys
its a MPFI system and once again you guys helped me out. It turned out to be one bad fule injector, it was getting power but the injector itself was grounding out causeing the rest not to work. thanks alot guys actually it was a fluke, i was told about that sort of thing happening to another guy so i just started with one injector and used an ohm meter to test it and after 2 trys i found one that was grounded out
One or more of them may have gone south on you.
