Hi-beam switch problem
Old Oct 20, 2004 | 09:28 PM
Not a Mechanic's Avatar
First, let me say 'hi' as I am new to this board and this is my first post. My name is Tyler and I have a '89 Camaro RS 305 TBI. Now on to the 'fun' stuff...
I spent all day tearing my steering column apart so I could replace my turning signal switch and when I went to put everything back together my hi-beam/cruise cont arm doesn't return to its original position. There is a rod that I believe attatches to the switch assembly(somehow) but I can't figure out how. When I pull the switch forward to activate the hi-beams, it doesn't 'spring' back to it's original position. I looked it over and over but it just ain't clickin...any ideas?
Thanks in advance
-Tyler
Old Oct 20, 2004 | 09:47 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Not about to tear my column apart to help you here. But I remember how much of a b*tch it was to get that back together my first time around.
Its been so long that I can't remember how it went together.
Do a search for "loose tilt column" Vader posted assembly pictures in one of the threads that may help you put yours back together.
Old Oct 20, 2004 | 10:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Maybe this will help you out some or at least point you in the right direction.
Old Oct 20, 2004 | 10:21 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 3
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 4
Old Oct 21, 2004 | 02:53 PM
Thanks a lot for the info guys...gonna try it out. Wish me luck.
Old Oct 21, 2004 | 06:47 PM
Thanks for the help guys...the rod had slipped out of the recepticle in the dimmer switch. All fixed. Now all I gotta do is firebomb Autozone for suggesting the most expensive/complicated fix for my turning signal when it just needed a $2/10 min fix.
This board is awesome...I'll definately come here (first) next time.
Thanks again.
-Tyler
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Street Lethal
Apr 30, 2019 12:14 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Fronzizzle
Aug 9, 2015 01:15 PM
