Which VSS should I get?
Old Oct 25, 2004 | 03:53 AM
85_TA_WS6's Avatar
Car: 1989 GTA
Engine: 350 TPI L98
I need to get a new VSS for my 1985.5 TA. It has a 700R4 transmission, the sensor is transmission mounted, The VIN is a G-code. I narrowed it down to three choices:
Trans mounted with D9A $64.82
w/Opt. Label
Trans mounted with D9E $35.93
w/Opt. Label
Trans mounted with D9B $71.43
w/Opt. Label
Im not quite sure what the "w/Opt. Label" means but it was on there so I figured I would put it up here. Can you guys tell me which one of these three speed sensors I need. Thanks for your help.
Adam
Old Oct 25, 2004 | 08:24 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Contact your Pontiac parts dealer. Give them your VIN code and they can tell you the correct VSS to use.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
