Problems with power hatch
Old Nov 1, 2004 | 04:58 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
The car is an 86 Iroc. We popped the trunk open today and the motor continued to run. Any idea what is wrong? I was reading through some old post and it sounds like it oculd be a broken gear nut? Also how can we close the trunk all the way? The trunk will latch but will not go down all the way.
Old Nov 2, 2004 | 09:52 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Does anyone know how we can get the trunk to shut all the way? Broken motor doesnt matter, just need the car to be driveable.
Old Nov 3, 2004 | 09:44 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Is that little black piece that is behind the latch stuck?
Old Nov 3, 2004 | 09:15 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Mike's diagnosis of a broken gear nut is correct. They can either shread the outer teeth or shear in half. To manually lower the latch you'd have to disassemble the hatch pull-down unit to expose the gear nut, then manually turn the gear to lower the latch, then reassemble the unit. It is easier just to replace the broken gear nut once you've disassembled it, since the same steps to dissassemble and reassemble would be required.
Mike the new gear nut should arrive shortly.
Lon
Old Nov 7, 2004 | 11:00 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Hey Lon, I really appreciate you getting the part shipped out fast Got here just in time for me to fix my dads car so he could make his trip. The job was pretty easy and the instructions helped out alot.
If any of you guys need replacement parts Lon is the man
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
Bert87
Aug 23, 2015 03:50 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
