Dead horn
Old Nov 12, 2004 | 04:02 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Dead horn
The beater Firebird ('87) has no horn. My Haynes manual has totally zip about it, no circuit diagrams or anything. Is there a troubleshooting chart floating around somewhere I could follow, or has anyone had experience with the stock horm system? Worst comes to worst, I could simply help the new owner wire in a new one, but why spend more money than we have to, right?
Old Nov 12, 2004 | 07:43 PM
Morley's Avatar
The most common failure with the horn is the contactor in the steering wheel. If you remove the horn button you'll see a wire on it that goes into a "straw" down in the column. The contactor may have just poped out, it is held in the "straw" by 2 pegs on it that go into grooves in the straw. Insert the spring contactor and push & turn 1/4 CW and let go. If it stays...good, if the horn works..even better, if not then the contactor ring down in the column has slipped. If the contactor pops back out of the "straw" then the notches in the straw are broken and you'll either have to replace the plastic piece that the straw is a part of or devise a way to hold the contactor in there.
Old Nov 12, 2004 | 10:13 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
In addition to what Morley has suggested, check the horn relay in the convenience center.
Old Nov 15, 2004 | 12:13 PM
Wezzeles's Avatar
Car: Camaro
in my car it happened and it was only a fuse. which was connected to bose radio, some lights, and the horn
Old May 30, 2005 | 02:21 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
My "straw" peice broke....how do I replace it?
Old May 30, 2005 | 10:26 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go to a auto parts store and get a new one, remove the steering wheel and replace it.
Veaceonee
Sep 29, 2016 08:15 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
