What does the plug near the AC condenser do?
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Im not sure if that is the correct name (AC condenser), the silver catch can on the passenger side has a round plug that goes into the hardline, what exactly is this for?
Thanks trickster, but don't believe thats the one im speaking of, this one is a very small round plug towards the front of the metal can.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Ok,
Let's try this picture then, it a picture of the accumulator with the low pressure cycling switch in the rear to the left. A big hard line going into it from the front, and to the right of that hard line where the "X" and arrow is located is the low side servicing port which is a schraeder valve. At least that is what it should be on cars that are stock and have not been modified. If that isn't it, I can't tell you.
There is also a small switch that is connected onto a schraeder valve on the hard line for the A/C high pressure side. On my car this switch is located on the line as it runs along the chassis beneath the overflow tank.
Damn, I don't have that plug, looks like I got to make a run to the junkyard. I thought the fan switch was located near the heater core and all that was needed is to wire the AC clutch.
89 formula TPI
Sep 7, 2015 11:06 AM
