dash lights not working
Old Nov 18, 2004 | 10:47 PM
musicfire67's Avatar
Car: 84 camaro
Transmission: stock 5 speed
I am wondering how many wires are there that controls the lights. I have tried finding them but I have had no luck. Its really annoying not having those at night.
Old Nov 18, 2004 | 11:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Which lights are you referring to? The ones in the dash or all the lights. Have you checked all your fuses, the dimmer switch, the ground wires, and the light bulbs in the dash?
Old Nov 18, 2004 | 11:08 PM
Car: 84 camaro
The lights that light up the speedo, tach, fuel etc. None of them work I have check all fuses and a ground wire and also replaced the lights.
Old Nov 18, 2004 | 11:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There are two ground wires under the dash for the instrument cluster. Which fuses did you check? Was it the INST fuse?
There is a green wire that goes from the light switch to the "INST" fuse, from there it is a gray wire that goes to the instrument panel lights.
Old Nov 19, 2004 | 12:03 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I believe those "dash lights" your referring to also are wired into the running lights. When you turn your heads lights on do your back tail lights turn on too? If they dont, I had this happen, was a fuse.
Old Nov 19, 2004 | 12:22 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You are correct Pasky, there are two fuses in that circuit. The "Tail" fuse gets power from a fusible link and supplies power to the light switch. The "INST" fuse in his car has a green wire running to the light switch and a gray wire running from the "INST" fuse to the instrument panel and associated lights. If it's not the fuse, then he should check that green wire and the gray wire.
Old Nov 19, 2004 | 09:17 AM
Car: 84 camaro
When I turn my lights on the taillights work. So where is this INST fuse??? If its on the fuse box can somebody take a pic and show me exactly where it is. I have an 84 and most of the writing on the fuse box is worn. Thanks
Old Nov 19, 2004 | 10:06 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, enjoy!!!!!!!!!!!!
Old Nov 21, 2004 | 01:46 AM
Car: 84 camaro
well I got them working turns out that it was the circut board on the back of the cluster panel. Thanks for your help
Old Jul 1, 2020 | 04:07 PM
seangreene99's Avatar
Re: dash lights not working
I was trying to replace my starter and I didnt disconnect the battery now I have no lights or anything what'd I do
Old Jul 1, 2020 | 04:49 PM
OrangeBird's Avatar
Car: 1989 Firebird
First , I'm not breaking your ***** here , I'm really not , , ,
but , , ,
bumping a 16 year old thread that isn't even discussing your problem isn't the way to go . Most people will see the 2004 date of the first post and pass the thread by without a look .
The original poster had no dash lights and it sounds as if you have no lights whatsoever , dash or otherwise , am I correct ?
Now to answer your question ; If you were working on the starter , and now large portions of the electrical system are dead , by far the most likely cause will be that one of your fusible links either didn't get hooked back up , or is electrically open (even if the outer insulation looks good the wire within can be bad) ....
hotrodln
Jan 9, 2013 09:36 PM
seawolf18
May 5, 2012 08:19 AM
87v6Bird
Oct 1, 2009 11:40 AM
DHays
May 16, 2004 11:52 AM
chrisfrerick
Jan 10, 2002 02:20 PM
