Low Voltage
Old Dec 23, 2004 | 02:02 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Low Voltage
Car is an 86 Iroc. The voltage guage only reads t about 10-11 volts when the car is running. If you rev it it will go up but then come back down. Sometimes the car is a little hard to start and the battery has needed to be recharged twice within the last 4 months or so. Yesterday my dad said it had a lack of power when accelerating. I had the alternator tested at autozone today and they said it was fine. What would cause the volts to be so low?
Old Dec 23, 2004 | 02:26 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
same problem here
Old Dec 23, 2004 | 05:02 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
do you have a deferent underdrive pulley if it is smaller it is going to effect the rpm of the aultn
Old Dec 23, 2004 | 05:12 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Well turns out it was the alternator. I took it to Autozone for them to test and they said it was fine. I wanted to get a 2nd opinion so I took it to Kragens and it failed. I then took it to Napa and it failed there as well. Damn Autozone I put in a new alternator and the voltage is back to normal so I would check that out crazy.
Old Dec 23, 2004 | 05:25 PM
Car: 2002 SS
Engine: Ls1
lol i kno its my alt.. my rf1001bd amp killed it... alittle bit ago
327IROC85
Sep 23, 2015 12:11 AM
gta_knight
Sep 17, 2015 03:48 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
