Fog light/High beam issue
Old Jan 4, 2005 | 08:21 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Recently I noticed that when I have my headlights on, if I turn the fog lights on, the high beams come on as well. Now I know the relay would kill the fogs when the high beams come on, but would a bad one cause the high beams to come on when the fogs are turned on? Also, the high beam indicator does not come on.
TIA
Old Jan 4, 2005 | 10:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I would check that relay and also the ground wires for it.
Old Jan 10, 2005 | 10:26 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks, I'll take a look. Hopefully the inspection station will be quick tomorrow so I can do it while I still have daylight.
Old Mar 19, 2005 | 10:10 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks. Finally got around to it, it was a problem with the relay. Cahnged the bulb on the indicator but it still doesn't work so there's another issue there. Thats not too big of a deal because I can tell visually when the highs are on.
Thanks for your help.
Old May 3, 2005 | 08:26 PM
iroc_cragg's Avatar
I have a problem like that too, My fog lights go out when I put the high beams on. Is this normal
Old May 3, 2005 | 09:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
yes it is!!!
db057
Apr 28, 2019 07:45 AM
TheTraut88
Sep 11, 2015 05:16 AM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
