Guage fuse blows
Old Jan 19, 2005 | 12:00 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
Guage fuse blows
previous owner did 350 swap on 86 irocz
But the guages arent working
I checked the fuse and there wasnt a fuse!
I put the number 10 fuse in and the tach worked
but the oil pressure and water temp arent working properly.
I drove the car for a few minutes and the fuse blew.
Not sure how to proceed, I am in the process of taking
the guage cluster out.
Other problems
speedo cable broke
wipers dont shut off once turned on.
Dave
Old Jan 20, 2005 | 05:58 PM
BOTTLEDZ28's Avatar
Transmission: A4
after you read this post, go to the store and buy a fire extingusher. It sounds like you may need one shortly. If a fuse blows it is because there is a serious overload onit or a wire connect to it is shorting out to ground somewhere. Now you say that oil pressure and water temp gauges arent working either. I would check the sensor on the drivers head and see if it is connected. The wire may have been burnt off and is grounding out on the header pipe. Does the cluster lights come on at all? I would start looking around for a really $hitty wiring job. Look at the connector on the wiper motor and see what it looks like. Look under the dash for a stuff that just dont look right. THere has to be a wire(s) somewhere that is shorting out that fuse.
Old Jan 20, 2005 | 10:57 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Fire extinguisher havent thought about that
I dont get to many lights comin at start up
the choke light did stay on
I checked the wire going to the choke while the engine
was running no power at the lead. choke is dead
Theres 2 sensors one for the oil and water
looks like the water sensor is in front and the oil is
back by the distributor that one doesnt have a wire
coming from it, I think its hangin down behind the engine.
As of now have to wait to work on the car for awhile
getting really cold again and snow is in the forcast
I wont be driving it until I get these problems fixed
thanks
for the advice
I might of bit off more then I could chew with this car.
Old Jan 20, 2005 | 11:05 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello HorseflyDF,
Seeing that you have a choke light, you obviously have an early model car with a carburated engine. If you would please tell us the year & make of your car I might be able to give you some ideas about your problem.
Old Jan 21, 2005 | 06:55 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Hi Trickster
This is an 86 IrocZ28
thats what the emblems say heh
350 engine
edlebrock intake
4bblholley carb 2160 series.
Might go with a manual choke kit eventually.
SO far Im getting the haynes manual for the car
and carb book.
I need help with electrical issues
but right now it got to cold to work on. 15 degrees now.
dave
Old Jan 21, 2005 | 06:56 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Might??? OMG, Trickster you slay me.. Trust me HorseflyDF, if anyone can point you in the right direction, it's Trickster.
Old Jan 21, 2005 | 07:35 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Thats encouraging to here and I am looking
forward to fixing the problems if I can.
I called a performance shop and they said to troubleshoot
electrical is 70 dollars an hour minimum.
I left my number and they never called me back
So I said in this case perhaps they left it up
to me to fix.
I told my son that Im not gonna punk out
just yet.
He asked what does that mean ?
I said I wont give up trying to fix the car myself just yet.
Dont give in unless you blow the car up.
this may be my new motto
Old Jan 21, 2005 | 09:07 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: Guage fuse blows
Dave
If they shut off when you turn the car off (wiper switch in off position) and don't come back on when you turn car back on (wiper switch still in off position), probably the park switch in wiper motor cover (ask me how I know).
Old Jan 21, 2005 | 09:17 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
wipers
As far as the wipers go
They turn on but the delay isnt working
and they dont shut off unless
the car is turned off
I put the wipers in the off position and they keep
on going like the energizer rabbit
Ive read this is common problem on Fbody
2 dollars plus tip
thats resonable
Old Feb 21, 2005 | 09:18 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
86 Irocz28
350 holley 4bbl 700r4
I looked under the dash many times and removed the
stuff that was in the way mainly the alarm harness
I havent been able to locate the problem.
There are so many wires that are hooked up
with the guage fuse its not funny.
I saw a diamgram where they spider
out all over to different sensors etc..
Considering I am only a nut and bolt guy
this will probably be a long shot to fix.
I wired up the electric choke but its on the guage fuse
and when it blew so did my power to the choke.
Have to find another circuit and I need to learn how
to wire up a relay and fuse for it.
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
