Hatch release what to get a little story for you
Car: camaro rs 305
Engine: 305 slow tbi
Transmission: slow aut
I just open the trunck today and as i m lifting I hear the motor goign nuts and not stoping the hatch release did unlock but the damnnn thing is not moving up,
I took the plastic cover off and disconnected the two cables on each side, replug it and still I hear the motor going.
A guy told me to just buy the whole new thing again which is 250 at hawk web site
I was wondering if it wasnt just the little gear
what do you think?
is it easy to change
please help meeeeeee
thanks a lot, glad the forum is back
Cedric
what do you think?
Cedric
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I would find the right height and drill a few holes and anchor it down. It works and takes a little efford finding the exact right slam force. Once you mastered that then you are a rear hatch expert. Report back on your findings so folks can further comment or learn something from it.
Engine: SBC, LS-x
Before hand I meant disable the motor and anchor it fast to the tracks.
Car: camaro rs 305
i m not sure what you mean, the motor when plug keep on turning not moving anything, I just thaught it was the gear that was eaten out....
right now the hatch is close, I had to push really hard on it , so I guess you mean I should re adjust the release but how since its stuck,
I need to mention that I m retarded with my hands
thanks
thanks
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Your plastic main gear has finally stripped out.
If you disassemble the unit you will see that the "gear" is flat on one side. I have a few pristine ones available if you need one after the disassemble.
Jim.
Jim.
Engine: SBC, LS-x
thanks
thanks
Remove the electrical leads from the hatch pull down.
Adjust it so it is fuly closed. Crawl into the hatch with a sarpee or some other marking device. Mark the rail where you would like it to be permanant.
Open the hatch and reach in and drill holes where you marked. Elongate them so you have some adjustment. Once adjusted tighen her down. Problem solved.
Axle/Gears: 3.45, 3.27, 3.27
Were you aware that I sell all the parts you'll need to repair it?
Yes, it sounds as if your gear nut is bad. The motor continuing to run without the latch portion moving is the classic symptom of a bad gear nut. I can see jerry rigging it if you aren't aware of the parts being available.
Lon Salgren
Top-Down Solutions
Lon Salgren
Top-Down Solutions
Car: 1988 Camaro - 1987 IROC-Z
Engine: 305 - 350TPI
Transmission: 700R4 - 700R4 w/shift kit
Today, my electric hatch release went out, it will shut, just part of the way, you can't hear the motor, it's not doing anything, I can open it with the key, and with the push button on the console, but when I shut it, it latches like a slam-down would, and isn't even with the spoiler, and leaks when I wash it. I'll include a couple pictures of it. (Yay for a girlfriend with a digital!) I've looked for the "switch" that everyone talks about, I cannot find it. Tried slamming it down harder like some others said- also, nothing happens. Please help?
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Slam it REALLY hard.
I had to do that once when I needed into the car I was storing. No battery.
Tried slamming it, very hard. I honestly think if it was slammed any harder, the rear glass would shatter.
Or keep slamming it and I'll sell you the parts that you'll break. You're choice.
Lon
Lon
Lon
Yes, but it really isn't necesary. Just look down the hole with a flashlight.
Lon
Lon
Lon
Lon
Went out there, with my half dead flashlight (haha) and I only seen one thing that it could be, unless it's further down. Do you have a picture of what it looks like?
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Having recently and still dealing with this issue, I did a lot of junk yard shopping. Of the 15-20 pull down units I found, atleast 11 of them had the "stay in one place" modification with screws, or welding etc..
I should note however.. if its just the screw, I just bought on from that Top down solutions for 7.00 . Its that link at the top of the forum. That would be the best place to start in resolving this problem.
Once you get it in, let me know if it works and I'll be the next to order it.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
been there, done that. nice post. give me a good late night chuckle.
Car: '86 Trans Am
Engine: LG4
Open hatch, leave up.
Place your index finger ( the one next to the thumb) where the loop on the hatch will go when it shuts in the receiver motor groove.
You will feel the plastic switch to the left side of your finger and the hatch motor will now travel "down" to its stop point. Remove your finger and it will now travel "up" again to receive the hatch when you shut it.
Jim.
Jim.
Place your index finger ( the one next to the thumb) where the loop on the hatch will go when it shuts in the receiver motor groove. You will feel the plastic switch to the left side of your finger and the hatch motor will now travel "down" to its stop point.
Jim.
Jim.
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
