Ignition coil
Old Feb 21, 2005 | 08:25 PM
kptkid's Avatar
Ignition coil
the other day I was idleing at a stop sign and the motor just died. today after testing everything it came out to be the coil. I went and bought a new one and put it in, the motor ran in the drive way fine. then I went to drive it and as soon as a got around the block it stalled. wouldnt start, so instantly i guessed it was the coil and went and replaced it. then went i put the second new one in this time it started up and about 3 seconds later it died right out and wouldnt start again. this tells me that something is making the coil go bad. I would like to know if anyone has had a problem similar or would know how to go about testing to stop the coil from going bad.
88 irocz 350 tpi
anyone with answers please help thanks alot.
Old Feb 22, 2005 | 09:18 AM
kptkid's Avatar
Anyone? I mean I really need to fix the car. If I were to buy a new coil its just going to burn out again and cant keep wasting money, i need to figure out how to fix it. If anyone has any ideas please help.
Old Feb 22, 2005 | 01:14 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
That sounds like a fuel problem. Maybe the pump is going out. You have gas in it right. Just my .02
Laters,
Conrad
Old Mar 1, 2005 | 09:06 AM
z28cp's Avatar
Ignition Module
DZ
85 Firebird 2.8 T5
soon to be 350 TPI T5
Old Mar 1, 2005 | 10:58 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Originally posted by z28cp
Ignition Module
This would be my guess also.
Old Mar 3, 2005 | 11:54 AM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
Transmission: it works I'm happy
is the dizzy cap on tight and it's holddown bolt?
is the car just dead until you put a new coil in?
Wouldn't a faulty ignition module throw a code?
Have you read the codes?
Old Mar 3, 2005 | 09:20 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Ignition module.
Happened to me a few weeks ago. Went through two coils before I figured it out. Go to your local bone yard and pick one out of a decent distributor and grab a second one to put away for the next time.
Jim.
Old Mar 4, 2005 | 04:58 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Nope...
Old Mar 4, 2005 | 09:16 PM
Heckler's Avatar
Car: 90 Firebird
Engine: 3.1L
Axle/Gears: Stock
Similar Problem
Same thing happened to me, I thought it was a fuel problem, but I've got no spark coming out of my coil, I know there's a couple things that can cause this, I did short/open checks on the coil and it came out fine, same for the pickup coil, so i was thinking it was most likely the ignition module itself.. sounds like thats the most common failure, is there anything I can check to be sure about which part is broke?
Old Mar 7, 2005 | 12:46 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
I think most <a style='text-decoration: none; border-bottom: 3px double;' href="http:/www.serverlogic3.com/lm/rtl3.asp?si=24&k=auto%20part%20stores" onmouseover="window.status='auto part stores'; return true;" onmouseout="window.status=''; return true;">auto part stores</a> can check the ignition module for you but you will have to remove it from the distributor.
Jim.
Attached Thumbnails Ignition coil-c-documents-settings-berry
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
