wheres the underhood fuses??
Old Feb 26, 2005 | 12:33 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
i have no power getting to the headlight module. the 2 that should always be hot, arent. in the hanes book it says theres underhood fuses. i cant find them anywhere at all. can u guys help? i heard somewhere it connects to the starter and my starter has been clicking maybe theres a loose wire?..i dunno...i hate electrical systems... id appriciate help if u can help.
Old Feb 26, 2005 | 01:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That would be the fusible links that are located down at the starter solenoid. You should also have a couple located near the battery.
Old Feb 26, 2005 | 09:52 PM
Car: 1985 iroc-z
alright cool, thanx man. ive give it a shot. i hope it works. i was gonna check the starter solenoid anyways. is it under the car? like is that the easiest way to get to it?
Old Feb 26, 2005 | 10:11 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes it is under the car on the passenger side connected to the top of the starter. A word of caution here, disconnect the battery first before you start doing anything in that area.
Old Feb 27, 2005 | 09:44 AM
Car: 1985 iroc-z
thank man, ive got power now! but....its still not getting to the motors, haha..but at least im closer..im thinking its a ground..
Old Feb 27, 2005 | 10:14 AM
Vader's Avatar
Try metering the incoming power to the module when an assistant actuates the motors. If the incoming power drops to nearly 0, you still have a connection problem. If it maintains voltage, you may have a module problem.
Old Feb 27, 2005 | 03:03 PM
Car: 1985 iroc-z
i guess now the lights go up, wont go down. theres a switch in the motor that makes them go down right? because the one motor on the drivers side stays on after its up the other one doesnt. and this only happens if i turn the parking lights on! its a confusing mess...i dont want to replaced the whole motor..or motors..
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
