hatch release on 87 bird
Old Feb 27, 2005 | 04:59 PM
87and 93birds's Avatar
Car: 87bird and 93 formula
Engine: 305 and 350
Transmission: auto
i want to install the eletric hatch release on my firebird. it has the switch harness behind the dash. i have the switch and it already has the sol. in the rear hatch comp. what else will i need and how do i do it?
Old Mar 1, 2005 | 03:45 PM
Engine: 305 and 350
Transmission: auto
anybody?
Old Mar 1, 2005 | 10:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by 87and 93birds
anybody?
You will also need the hatch release relay, the hatch pull down unit and the wiring. I will e-mail you the schematics for it tomorrow along with a trouble chart.
Old Mar 2, 2005 | 04:33 AM
Engine: 305 and 350
Transmission: auto
thanks. michael_mciver@msn.com
Old Mar 2, 2005 | 05:33 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I believe you'd want to install the entire hatch motor assembly. Not to advertise, but I've got a complete hatch motor assembly in the classifieds.
Old Mar 3, 2005 | 12:31 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
His car should already have a hatch pull-down unit. All he needs to do is swap the manual hatch release on it for the solenoid hatch release . He'd also need to add a ground wire from the 10mm screw that attaches the solenoid release to the pull-down. The other end of the ground wire attaches to the ground location on the body below the hatch pull-down unit. You'll need to run a +12v wire from the solenoid relay back to the solenoid. The relay you're seeing below the hatch pull-down unit isn't for the solenoid release. It is for the hatch pull-down unit. The hatch release solenoid on Firebirds is located in the dash behind the where the switch goes. On Camaro it is located beside the emergency braks and grounds through the e-brake. Firebirds should have a ground through the e-brake also, but I haven't confirmed it yet. Look at the schematics Trickster has sent you.
Lon Salgren
Top-Down Solutions
Old Mar 3, 2005 | 04:39 AM
Engine: 305 and 350
Transmission: auto
he hasn't sent the scematics yet. i have the pull down and release sol. already in place just need to know where the sol is and how to get power to the sol.
Old Mar 3, 2005 | 09:02 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry about sending them late, My work schedule changed. I will get them in the e-mail today.
Old Mar 3, 2005 | 01:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check your E-mail, you have a package.
Old Mar 4, 2005 | 05:01 PM
Engine: 305 and 350
Transmission: auto
thanks that will do the trick
Old Mar 13, 2005 | 05:51 PM
Engine: 305 and 350
Transmission: auto
just got the relay and wire for the release from a donor car in a yard. there was a connection by the fuse panel but i cant seem to find mine. there are 3 wires at the relay . so there all there. do i keep looking or do i have to run it from the relay?
Old Mar 13, 2005 | 08:06 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Is it possible to get a copy of the schematics and the trouble chart from somebody? I have problems with the one installed on mine. I thought the hatch was bent but maybe the motor is just stuck.
Old Mar 13, 2005 | 09:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Scorpner, you have e-mail.
87and93birds, that connection that you are looking for is a red/white wire that goes to the "LID" fuse. It is an inline fuse located by the fuse panel, it is probably buried in the wire bundle there.
Old Mar 14, 2005 | 11:50 AM
Scorpner's Avatar
Engine: V6, V8
Thanks,
It's much appreciated.
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
