swapped engine now car dies when i pull neg bat cable
Old Mar 5, 2005 | 09:24 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
the engine dies when i pull the neg bat cable. the alt was tested and it passed. what am i missing here. i have a 2 wire plug and that plug goes to the plug and then a red wire which i put on the alt where the screw goes to on the back side of it. what am i missing.
trickster please help anybody please help
jon
Old Mar 5, 2005 | 09:36 PM
semiller26's Avatar
Car: 1986 Trans Am
what do you mean by pull the cable? pull it off? or just nudge it?
Old Mar 5, 2005 | 09:43 PM
semiller26's Avatar
Car: 1986 Trans Am
how bout I just come over and help you screw it up a little bit more
Old Mar 6, 2005 | 10:52 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
On most cars that is a normal occurance since what you are doing is removing the ground.
Old Mar 6, 2005 | 12:54 PM
jocww's Avatar
but it shouldnt my shop teacher says if i do that then im running off of the bat and not the alt. and if i gas it the current reading doesnt move it stays at 12
Old Mar 6, 2005 | 01:01 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
If I understand that correctly, how could it be running off the batt if you just pulled the cable off? What are you trying to do, anyhow?
Old Mar 6, 2005 | 01:26 PM
conlinj's Avatar
you pull the positive off not the ground...
Old Mar 6, 2005 | 01:54 PM
jocww's Avatar
ok the pos not the neg ok. well lets see if it still runs.
Old Mar 6, 2005 | 01:55 PM
jocww's Avatar
that still doesnt solve the problem i have with it not fluctuating when i gas it.
Old Mar 6, 2005 | 02:05 PM
jocww's Avatar
pulled the positive off and guess what it died
Old Mar 6, 2005 | 02:06 PM
conlinj's Avatar
what do you mean not fluctuating? like not accelerating
Old Mar 6, 2005 | 02:11 PM
conlinj's Avatar
how bout if you leave it running with the cables on does it eventually die or stay running? you have the other connector that goes into the side of the alt connected still and the cable that goes to the post on the back of the alt?
Old Mar 6, 2005 | 02:49 PM
jocww's Avatar
when i accelerate the or give the mtr gas. the voltage reading stays the same. and yes the engine stays running if i dont disconnect the cables.
Old Mar 6, 2005 | 02:50 PM
conlinj's Avatar
how many volts is it reading and how long will it stay running?
Old Mar 6, 2005 | 05:32 PM
jocww's Avatar
12 and until the bat dies
Old Mar 6, 2005 | 08:12 PM
jocww's Avatar
its all good my uncle and my dad fixed it for me
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
