cigarette lighter blowing fuses
Old Mar 24, 2005 | 01:41 AM
robleamy's Avatar
Car: 92 z28
ok heres the story, ever since i bought my 92 z the cigarette lighter was missing. then one day i tried to plug an accessory into the lighter and nothing happend. so i took the guage trim off and it wasnt plugged in. so i plugged it in and it blew the acc. fuse. so i tried it two more times and it blew the fuse two more times. any ideas on what is going on.
Thanks, Rob
Old Mar 24, 2005 | 08:12 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The housing is shorting out the wire. It is either bad or maybe there's a penny or something down in there causing it to short. With the power lead unplugged, check if the power terminal on the housing has continuity to ground. If so and there is no foreign object in it, replace housing.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
