indentify this plug.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
looks like a map sensor plug.lets see if others agree with me
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
that does look like a map sensor plug. i have 2 on my 84 z and its a carb. there is one on the right and left of the firewall http://www.cardomain.com/memberpage/804037/3 1st pic enlarge it and you can see by the brake booster and 1 by the ac crap. oh and dont mind the paint couldnt make up my mind lol.its all getting redone anyway.
. and i know about the spark plug and the wires on the exhaust mani. i just wanted to hear the car run.lol
. and i know about the spark plug and the wires on the exhaust mani. i just wanted to hear the car run.lol Last edited by 84camz28; Apr 3, 2005 at 09:28 PM.
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
84 h.o used a map sensor and a baro sensor, the baro sensor was mounted right over by the a/c stuff on the firewall I'm positive thats the baro sensor plug
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
All Carb engines with CCC(ECU) uses MAP Sensor. The connector may also be TPS connecter at the CARB. Both the TPS and MAP sensor uses three wire connectors.
Bruce
you are right the the LG-4 and the L-69 both used maps, however the 84 L-69 had a baro sensor as well as a map sensor, this is what that plug is for my 84 L-69 trans am had that plug right there too.
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Can someone post a picture of the Baro Sensor? I have that same wire un-plugged and can't find the Baro Sensor. I also have an L69. Why would they have a Baro sensor and the other motors not?
1989formula5.7l
Aug 17, 2015 02:56 PM
TomP
Mar 30, 2001 06:31 PM
