2 wires on the alternator?
Old Mar 30, 2005 | 05:15 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Its a long story so i will just cut to the chase.
On the stock connector and stock replacement alternator for a LB9 730'ecm where does the BLACK wire on the connector suppose to go?
Its ohming out in the mega ohms like 3.2 or something. If i leave it hooked up to my alternator it wont charge.
So i have it ran to my fuse panel. BUT...i have it switched b/c if i leave it directly hooked up to a 12v source my battery will go dead over night.
Thanks for any help.
Here is a pic of what wire im talking about. Its the black one that the red arrow on the left is pointing to.
Old Apr 5, 2005 | 11:18 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Your alternator has the two wires on the connector you show. The brown colored wire should go to a switched 12 Volt, basically on with key. That is what turns the alternator on to start charging the system. I had left it disconnected on my car and my battery was dying also. I believe that the other two wires go to the starter.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
