VSS Buffer Box
Old Mar 31, 2005 | 10:11 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
VSS Buffer Box
On the VSS Buffer box, I know what most of the pinouts are.
From http://la.rsson.com/speedo/speedo.html
Sensor related:
Purple - from sending unit
Yellow - from sending unit
Pink with black stripe - switched 12V power
Green with black stripe - to speedo
Black with white stripe - ground
Now there is Brown and Red with black stripe
as seen there.
I am told that the ECM needs a signal from a buffer and the old gage cluster had a pinout for "BUFFER SIGNAL TO C3 COMPUTE" and "C3 COMPUTER GROUND TO BUFF"
I'm guessing that the brown is for "BUFFER SIGNAL TO C3 COMPUTE" but is it safe to assume that the red wire is for "C3 COMPUTER GROUND TO BUFF" ?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
tattmann
Sep 27, 2015 05:20 PM
