Need help, Alternator, wiring?
Old Apr 9, 2005 | 06:25 PM
WhiteGhost's Avatar
Car: 00 Trans Am
Hey guys.. I went to my parents to hook up the a tach that I bought, and also wire my fan to run with the switch.. so I spliced the positive wire going to the fan and ran an 8 guage wire to an ignition spot in the fuse block.. easy.. then we hooked up the tach.. its a autometer autoguage 5" w/light.. the green wire from the tach went to the white wire coming out of the coil to the distributor.. the black was ground, the red was ignition switch which I also hooked up in the fuse block.. the white wire from the tach went to interior lighting so I took the easy way out and bent the end of the wire around the end of the fuse for the instument lights.. everything worked great.. fan runs, tach works.. I drove off the driveway and the engine quit.. dead as a door nail so we jumped it from dads truck.. looked at the guage and its reading about 10.. which told me the alternator was bad.. took it to autozone, and had them run a bench test.. its good.. came back and checked all the wiring we did.. still nothing.. so we unhooked everything we did.. still nothing.. the car is NOT charging at all but the alternator is good.. what else should I be checking?? I am going back tomorrow morning to work more on it.. so all the replies I can get tonight would be great.. please help guys.. and if the mods can leave this at the top for tonight I would greatly appreciate it..
Thanks in advance
Scott
Old Apr 10, 2005 | 05:13 PM
WhiteGhost's Avatar
Car: 00 Trans Am
ok.. im either going to have to rewire the entire charging system or something.. because the alernator is good.. the battery is good.. everything works great.. car just wont charge.. oh well.. not getting any help here
Old Apr 10, 2005 | 07:16 PM
87 convertible's Avatar
Car: 87 20th anv lt sport coupe convertible
Transmission: 700 r4
i had charging problems to, what i did was ran a wire 12 gauge i believe from the positive battery terminal to the alternator itself, i wired it to the post on the back of the alternator where the wire is held on with the small nut, i don't know how safe this is ,but i have never had any problems with the connection, and my car push's about 13 volts while running. good luck
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
