Error Code 42
Old Apr 16, 2005 | 12:03 PM
Pdiminico's Avatar
Car: 88 IROC
Engine: 5.O TBI
Error Code 42
Need help trouble shooting a code 42. This is an 88 TBI engine. While in park or in motion car will begin to stall and the check engine light comes on.
Old Apr 16, 2005 | 12:53 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
42. Fault at electronic spark timing circuit OR
Fault at direct ignition system OR
Fault at fuel cutoff relay circuit
Old Apr 16, 2005 | 12:54 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
good luck check your distributor they tend to go bad
Old Apr 16, 2005 | 01:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have posted this in the past and will post it again. Hope this helps, an item that you might want to cjeck here is the ignition control module.
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Apr 16, 2005 | 02:36 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
it shouldn't display the code for the icm, mine didn't, I actually am running code 42 right now because my timing is off just check your distribution components
Old Apr 16, 2005 | 09:53 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It would show a code 42 if you had a short to pin "D" of the ICM.
Old Apr 17, 2005 | 08:39 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
yeah that i learned today, but if it isn't working properly it wont if he is starting and stalling..........
Old Apr 18, 2005 | 03:06 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You'll also show a 42 if the EST connector is disconnected for you to set the base timing and you forget to plug it back in. Ask me how I know.
Old Apr 18, 2005 | 08:00 PM
Pdiminico's Avatar
Car: 88 IROC
Engine: 5.O TBI
Error Code 42
The code 42 is intermittent and I have already replaced the pickup coil and the ICM. The EST connector is connected. The car starts to stall, comes back to life and kicks on the SES light. I only find the 42 in the ECM and not sure how to start trouble shooting. I cannot reproduce the problem at will.
Old Apr 20, 2005 | 08:42 PM
Pdiminico's Avatar
Car: 88 IROC
Engine: 5.O TBI
ECM
Swapped out my ECM and the issue seems to be resolved.
Old Apr 21, 2005 | 10:02 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: ECM
Step 5 of the trouble shooting chart posted above.!!!
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
