no crank / no click - full power
Old Apr 30, 2005 | 10:24 PM
sp63
Guest
Posts: n/a
sorry to post this twice, i didnt see electronics at first.
njspeeder said touch pos side of batt to some wire on starter with jumper cables.
so ...
blue i couldnt get a jumper cable on
top red = sparked
bottom red = nothing
does this mean bad starter?
bad vats?
bad something else?
how about i have to clamp jumper cables onto pliers and touch them to that blue wire? (might fit that way)
Old Apr 30, 2005 | 11:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Not sure what you classify as top and bottom from looking at that picture. The big connector there with the three or four wires has a large cable coming from the positive cable on the battery. The large connector below it is the shunt coil connector (not on all starters) connecting the starter and starter solenoid. The purple wire on the small terminal marked "S" goes to either the Park/Neutral switch (automatic) or the clutch safety switch (manual). What are you trying to accomplish here?
Old May 1, 2005 | 09:39 AM
sp63
Guest
Posts: n/a
top of pic
bottom of pic
red / red at their respective edges of the picture.
anyways.
my car wont start, crank, or even click when i try and start it. it has full power to everything, like my radio works, elec fan, etc.
he said it could be my starter or my vats or something, sowe were testing this theory:
if i can jump the batt to the staretr and get it to crank then i know its the vats or something else thats broke and NOT the starter.
make sense?
so.....
at this point it looks like my starter is bad??
Old May 1, 2005 | 10:12 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check your e-mail and see if that info will help you.
Old May 1, 2005 | 10:30 AM
sp63
Guest
Posts: n/a
ill run over itl ater. looks good so far. i appreciate your help.
Old May 1, 2005 | 09:15 PM
sp63
Guest
Posts: n/a
new starter and it works fine.
thx again.
BRoss99
Aug 10, 2025 05:08 PM
B_Dubya
Aug 26, 2015 05:09 PM
Linson
Aug 21, 2015 02:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
