Main battery ground
Old May 1, 2005 | 10:30 PM
Frank_Blotto's Avatar
Car: 87 Camaro Z28
Engine: LG4, CCC
Main battery ground
Ok, here's a quick, easy one for ya. Where exactly does the big black ground from the battery connect? I disconnected it in the process of changing my waterpump, and forgot where it goes. Thanks!
Old May 1, 2005 | 11:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To the lower front corner of of the engine block on the same side of the car as the battery.
Old May 1, 2005 | 11:41 PM
Car: 87 Camaro Z28
Engine: LG4, CCC
Haha, ok thanks.
Old May 2, 2005 | 12:09 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
where does it go from the engine block? how does it connect to the car frame, etc??? thanks
Old May 2, 2005 | 12:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It goes to the negative post on the battery with a small ground wire splicing off to the frame near the battery.
Old May 2, 2005 | 12:24 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
ok, thanks, i thought the ground wire going to the frame was larger.....
Old May 2, 2005 | 01:29 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You might be thinking about the braided ground strap that connects the firewall to the back of the right cylinder head.
Old May 2, 2005 | 01:33 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
whats that braided cbl for???
Old May 2, 2005 | 01:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
a ground!!!!!!!!!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
