Need Help With My Speedometer!!!!
Old May 3, 2005 | 05:11 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
ok hopefully someone can help me right before i put my new trans in the speedometer was working but i took a corner it wouldnt i found out that i pinched a wire so i fixed it when i put in the new trans and after i got done my speedo didnt work so i have checked the VSS because the VSS code comes up and its new so i checked the buffer box and its good so i went out and bought a new speedo and it doesnt work im wondering what else could it be i have checked all the wires that go from the trans to the cluster and there not pinched or cut as for as i can see i was hoping someone can get me any advice or something i can do to check things with like a volt meter or something i will try everything thanks for your help
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
