alternator problems
Old May 13, 2005 | 09:48 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
alternator problems
I was removing the alternator & forgot to disconect the battery
I saw a spark when the screwdriver touched the alternator cover & the bolt for the cable. Now the battery died so In thinking the alternator is fried, but is there a fuse or something I should check before I blame it on the alternator. Can anyone give me any advice?
Old May 13, 2005 | 10:52 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
There is a "heavy" guage wire straight from battery to alternator. No links or fuses as far as I know. Maybe you blew a diode or anything else in the alternator. I'm no expert but I've never heard of a battery dying from a short like that.
Old May 13, 2005 | 04:17 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
No, sorry for the confution. the batery died 2 days after the insident. Im asuming is related.
Old May 14, 2005 | 01:56 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
I have a pretty fuzzy memory but I think I replaced my own alternator at least once. I JUST sent payment for a reman unit off eBay, $45 bucks. Not too bad, however, the reason I did that was after testing a newer Delco radio in my ole '89... and my '88 Deville, I ran into drained batteries and in the 89 Formula's case, my alt guage reading very low WITH the motor running.
How's your Alt guage at this point? I contribute my reading as an indicator the battery is suppying all the juice. I bought a couple batteries to always have a backup and never need to have someone give you a jump....that only solves the immediate problem. With a charged battery, your good to go for some time
Bill
Old May 14, 2005 | 02:32 AM
Car: 86 T/A
Engine: HSR 355
Got a volt meter? Measure voltage with car off, then with car running. Off should be about 12.5V when charged, running should be 14.5V-15V. Sounds like alternator isn't charging battery properly, could be any sensitive component inside the alternator.
Old May 14, 2005 | 03:37 AM
Bill Speed's Avatar
Engine: L98 350 TPI
Technically Alt guage is an improper use on my part...the manual calls that a voltmeter as well... a bit confusing
Bill
Old May 14, 2005 | 09:23 AM
Car: 86 T/A
Engine: HSR 355
Bill
A meter that measures voltage... makes sense to me.
Old May 15, 2005 | 02:04 PM
Bill Speed's Avatar
Engine: L98 350 TPI
I guess having the symbols on dash for so long, and in the case of my Cadillac, in the digital readouts only during trouble shooting left me a little hare-brained
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
