horn and dome light diagrams
Old May 20, 2005 | 12:39 PM
350andacase's Avatar
Car: 88 camaro
Engine: 305 tbi
I've been avoiding this post for a while, but I just can't figure it out!!!!!!! HELP!!!!
Here's the scoop; 88 camaro 305 tbi all stock. I just can't figure out why the horn and the dome light is not working. All the switches (door, headlight, inside steering wheel) seem fine.
Trickster, do you think you could save me a trip to the looney bin with some diagrams?? Also, the 2 aren't both somehow connected are they? Everything else electrical works fine. Any help would be appreciated.
thanks
D4
Old May 20, 2005 | 09:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The only thing that they have in common is the fact that they both have a splice coming off the "ACC" fuse. I will get you the schematics shortly.
Old May 20, 2005 | 09:13 PM
Car: 88 camaro
Engine: 305 tbi
Thanks for the thirdgen fast response
Old May 20, 2005 | 10:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here are the schematics for the horn and "ACC" fuse. Hope this helps you.
Old May 20, 2005 | 10:33 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Please note in the first picture here that the wire from the "ACC" fuse goes to the horn relay in the convenience center.
Old May 21, 2005 | 08:51 PM
Car: 88 camaro
Engine: 305 tbi
Thanks again for the diagram. I think this should do the trick.
Old May 29, 2005 | 02:29 PM
Justin Horne's Avatar
Car: 1982 Z28
Engine: 350 HO
Transmission: TH350 to go in next week
Could this be my problem too?
My horn doesn't work, and the two little lens like lights on the overhead don't work.. Mind you, my 2x3 or so inch plastic covered light does work, just not the two with the switches.. Is this my problem too?
And if so, for those of us who really don't know all that much about cars, exactly what is his diagram showing me how to fix?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
fasteddi
Sep 10, 2015 09:32 AM
andy74
Sep 3, 2015 08:41 AM
Omega
Aug 10, 2015 12:46 PM
