Cruise Control, long drive
Old May 22, 2005 | 08:13 AM
KnightRiider's Avatar
Car: 82 trans am (knight rider)
Engine: 305 Carb
Transmission: 4 speed (want an automatic)
I have an 82 trans am what would be the reasons the cruise control would not work? And also i live in new jersey is it not reccomended to drive to tampa flordia in that car?
Old May 29, 2005 | 02:55 PM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Hi
Check the following,
1) Vacum line to the modulator.
2) Brake switch
3) Switch on turn signal stalk
4) Modulator
5) Mach linkage between the vacume motor and the carb.
I have an 1982 Firebird, I could easily drive it across country if I had too but them the enitire running chassie is almost new. It all depends on the conditions of the drive train, motor, brakes, tires, etc. Please remember Fla is somewhat hotter then NJ and that most failures on automobiles happens in the heat of the summer.
You will also have to be able to maintain 75/80 MPH on I95 is order to keep it safe. If you can't maintain that speed you will get the fools in the SUV's that will run right up on you bumper before they will change lanes to pass you.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
