which wire to use for a solid 12V source in fuse box?
Old May 26, 2005 | 12:40 AM
Max Dunlap's Avatar
Car: white 3.1L'90 v6 Firebird
alright what would be the best 12V DC source around the fuse box area that I can tap into? which wire? how?
also where would I get the ground from under there?
Old May 26, 2005 | 08:24 PM
Max Dunlap's Avatar
oh cmon, how about using the 12V source and ground from my radio? will that effect the way my radio works at all?
Old May 26, 2005 | 09:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Exactly what are you planning to use that 12V source for?
Old May 26, 2005 | 10:05 PM
Max Dunlap's Avatar
An iPOD charger
Old May 26, 2005 | 10:12 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Can't you just plug it into the cigarette lighter and use that or are you planning a special application or mod in your car for it?
Old May 26, 2005 | 10:41 PM
Max Dunlap's Avatar
Psh well who wants a big thing sticking out of their cigarette lighter and besides im pretty sure it doesnt even work? So I want to hide it under by seat. ive already fastioned up a housing and everything for the charger all i need it POWERRRR
Old May 26, 2005 | 11:07 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Just tap into the positive and negative wires going to the cigarette lighter then.
Old May 27, 2005 | 12:18 AM
Max Dunlap's Avatar
how would you get to that?
Old May 31, 2005 | 10:13 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
Don't know exactly what your fuse panel looks like, but if it's like the 80's cars, there are plenty of spare "accessory" terminals (one connector slots) that can be used to supply battery 12V or ignition 12V.
That would be the "right" way to get power, along with fusing that lead appropriately. You can cut/splice a connector from a wrecking yard donor so that you have a locking connector.
Most GM panels use a circuit breaker for all accessory terminals, but they are "ganged" on a 30A breaker, which is typically way too much for accessories, short of power windows, etc.
Old May 31, 2005 | 10:54 AM
Car: 86 T/A
Engine: HSR 355
From the back of the cigarette lighter.
Old May 31, 2005 | 12:23 PM
Max Dunlap's Avatar
yeah I got it working I looked at it for a while and started to figure out how to take off the panels until i got to the cigarette lighter
Old Jun 1, 2005 | 10:25 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
can you run power windows off of the cigarette lighter wiring?
/putting in automated window system
Old Jun 1, 2005 | 12:25 PM
Car: 86 T/A
Engine: HSR 355
Even if it doesn't pop fuses you still risk a fire. Windows can draw alot of current and may burn up the wires.
Old Jun 1, 2005 | 12:36 PM
ScrapMaker's Avatar
anyone know how large the wires are that run to the windows are? and where do they get power from?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
apie2546
Aug 8, 2015 07:12 AM
