Manual operation of Headlights
Old Jun 2, 2005 | 05:39 PM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
After using the search function, I unearthed many useful facts about the 'bird headlights - thanks guys!
HOWEVER, what do you have to do to get the lights to go up and down manually? Does the ignition have to be on? Do the lights have to be on? Do I turn the dials slightly, or keep winding on them? When I tried winding them (Ign. on), the dial suddenly whipped back out of my fingers.
Incidentally, my headlights work fine (for now!) - the passenger's one sometimes lags behind the driver's one when being switched off.
Anyone shed any light on the subject? (Sorry!)
Cheers,
Mark (newb Limey Pontiac owner)
Old Jun 2, 2005 | 07:30 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes turning the **** will manually raise or lower the headlights IF the gear (on 1982-86, aka 3-wire actuators) or gear bushings (on 1987-92, aka 2-wire actuators) are good. If the gear or gear bushings are stripped then you may not be able to raise them with the ****. You might be able to pull it up while rotating the ****. I sell a repair kit with a CNC machined brass gear to repair your headlight actuator. It also includes a trouble shooting guide to help track down the problem with your headlights.
Lon Salgren
Top-Down Solutions
Old Jun 2, 2005 | 10:11 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
*deleted*
Old Jun 4, 2005 | 05:22 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Re: Manual operation of Headlights
They're still receiving power to keep them pulled down. There are internal limit switches to prevent the motor from constantly trying to turn; when you turned the **** to lift the headlight, the limit switch made contact and pulled it back down on you.
If you wanted to manually rotate the ***** to raise/lower them, just unplug the 3-pin connector near the motor. If you want them to stay up all the time, turn the lights on to raise them before dis-connecting the plug.
Old Jun 5, 2005 | 06:52 PM
Difflock's Avatar
Thanks guys!
Mark.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
