beefed up alt
Old Jun 5, 2006 | 09:18 PM
  #51
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
The only reason I asked was when I put my cs-144 Alt in, I used the stock belt and it stayed in the same position as the old SI that was in its place. I didnt have to do anything except for mount it, and yes I do have the same 5 rib pulley on the alt. I just wanted to know how did mine fit just like the old SI I had.
Old Jun 11, 2006 | 06:35 AM
  #52
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
1986tpiiroc
Cool, glad it works. I been pretty busy this week at work. This new belt has a shorter throw and works great for me. Not sure why it needed a shorter one, other than probably the case design is different. Does your engine run any differently with this alternator?
Old Jun 11, 2006 | 01:48 PM
  #53
Car: 1986 IROC-Z
I dont notice any real performance difference in the engine, but my engine has always felt responsive anyway since I got the chip and put headers on a few years ago. The only difference I notice now is that when the car goes to idle, it maintains 13.4 volts while the car is fully warmed up and 13.8 - 13.9 while driving. No more dimming lights while my stereo is playing. Best upgrade ive done in a while. I'd try to post pics, but I dont know how.
Old Jun 13, 2006 | 01:21 AM
  #54
Lucid's Avatar
1986tpiiroc
Glad to hear. Im itching for some headers but i want to put some SFC's on first.
Well if you have a digital camera, and can upload them to the computer... When you post, theres a user panel above the text box. Theres a button of a paperclip that says attachments, and below the text box theres a button under additional options that says manage attachments. Press one and upload the photo by browsing your picture folder.
Old Jun 26, 2008 | 01:26 PM
  #55
Lucid's Avatar
Re: beefed up alt
I know this is an old post but I just wanted to try to elucidate the differences between the earlier years 82-84 and some of the later model brackets.
I was recently asked about an 82 and noticed that Chevy used a similar bracket in the carb trucks. Then I was walking through the garage and my friends 84 alternator and bracket was just sitting there on top of his car so I took some pictures.
The carb bracket seems to be horizontally flat (at a slight angle) at the manifold mounting tab to go straight down in the carb manifold. The TPI bracket seems almost to be vertically flat (also at an angle) to bolt to the TPI manifold.
84 carb bracket and alternator on the left, TPI bracket and CS144 on the right
Attached Thumbnails beefed up alt-imga1329.jpg   beefed up alt-imga1330.jpg   beefed up alt-imga1333.jpg
Old Mar 10, 2009 | 03:52 AM
  #56
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: beefed up alt
sorry to bring the thread back up from the dead but I decided to the CS swap myself. I'm running short on $$ and am a bit impatient since my current daily driver is suffering... Does anyone know where I can a 12v 35 ohm resistor? Can I just go into Radio Shack and ask for one and wire it accordingly in-line on the proper wire? Thanks for the info...
Old Mar 11, 2009 | 02:40 AM
  #57
HCR13's Avatar
Car: 1987 Trans Am
Re: beefed up alt
anyone?
Old Feb 15, 2019 | 11:56 AM
  #58
Lucid's Avatar
Re: beefed up alt
NAPA Part Numbers for Harnesses:
EC82 - SI to CS Conversion Harness for Volt Gauge
EC80 - SI to CS Conversion Harness for Idiot Light
GM Part Numbers:
Delco 8078/GM 12102921 if you have a volt gauge or
Delco 8077/GM 12083462 if you have an "idiot" light.
92projectcamaro
Dec 8, 2015 12:25 AM
BDR
Nov 7, 2015 03:05 PM
Zell1luk
Sep 29, 2015 10:36 AM
J.C. Denton
Sep 21, 2015 04:23 PM
Slush92RS
Sep 2, 2015 08:56 PM
