High beam/ cruise control problems
Old Jun 7, 2005 | 05:54 PM
NCGiant's Avatar
Car: 1990 Iroc-z convertible
Engine: 305 TPI LB9
Transmission: 700 R4
The stick on the left side of the steering wheel doesnt "click" when I pull back on it to engage the high beams. Also, the Cruise control doesnt work either. Are these problms related? Is the cruise control just on a fuse, or is there a bigger problem?
Old Jun 7, 2005 | 06:36 PM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
They're not as directly related as you would think.
When you pull back on the stick, it works a slider which pulls on a linkage. That linkage goes about halfway down the steering column to the actual dimmer switch.
All the switches/buttons for the cruise control are right there in the stick, and it has a cord containing 4 wires that feeds down the steering column to where it plugs into the wiring harness.
About the only thing that could be a common cause to both problems would be if someone was working down under the steering column. The cruise wiring could have been knocked loose, and the dimmer switch linkage could have been bent or knocked out.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
