Fuel Gauge Wiring
Old Jul 1, 2005 | 08:23 PM
Louverless's Avatar
Car: 1990 Camaro RS
Engine: 350 Crate
Transmission: 700-R4
Fuel Gauge Wiring
Okay, I have a 1990 Camaro Rs with a 350 carbed motor.The original owners stole the tbi 305, my poor rear louvers, and cut most of the harness.I am using the stock mechanical pump on the motor and cut the elec. fuel pump relay. Now I want to figure out how to have the fuel gauge working without the elec. fuel pump. Any advice would be appreciated thanks.
Ps: diagrams appreciated that make sense thanks.
Old Jul 2, 2005 | 10:44 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you still have the sending unit in the tank you will only need the pink wire going to the gage from the unit and a ground. The sending unit operates off of OHM resistance. No power source required.
Old Jul 2, 2005 | 04:26 PM
Louverless's Avatar
Car: 1990 Camaro RS
Engine: 350 Crate
Are the two wires for the gauge separate or go into a harness on the back of the instrument cluster. If in a harness what are the pin locations. Then does it go through the driver side floor to the back? Thanks alot after that I think I should be able to handle it thanks. I got my windsheild today from a firebird for $50 and my iroc-z hood for $20 with louvers from my local salvage yard was that a good price?
Old Jul 3, 2005 | 01:17 AM
Louverless's Avatar
Car: 1990 Camaro RS
Engine: 350 Crate
Hmm, my speedo and tach work until i turn on my interior lights and outside lamps. We found a wire that was black with a yellow strip going to a relay with 2 yellow wires and a peach with a white stripe. Grounded the black and yellow now fuel,amp,oil,tach, and speedo work excellent even with lights on.
What is this relay? It's located behind the driverside kick panel closest to the floor?
Old Jul 3, 2005 | 10:16 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is most likely your starter enable relay.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
